Protect the switch against IP packets with illegal IP addresses such as loopback addresses or a source IP address of ones, or Class D or Class E addresses from being routed. The switch supports high-secure configurable flag.
Important
After you enable this flag, the desired behavior (not routing source packets with an IP address of 255.255.255.255) applies to all ports that belong to the same port.
Important
The setting to enable hsecure only takes effect for packets going to the CP; not to datapath traffic.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface GigabitEthernet 1/16 Switch:1(config-if)# high-secure enable
The following table defines parameters for the high-secure command.
Variable |
Value |
port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Specifies the port on which you want to enable high-secure mode. Identifies the
slot and port in one of the following formats:
enable |
Enables the high-secure feature that blocks packets with illegal IP addresses. This flag is disabled by default. Use the no operator to remove this configuration. To configure this option to the default value, use the default operator with the command. |
